Enable SPB-PIM Gateway on a Brouter port.
- In the Device Physical View tab, select the port you need to configure.
- Select IP.
- Select the SPB-PIM-GW tab.
- Select Enable.
- Select Apply.
SPB-PIM-GW Field Descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
Name |
Description |
Enable |
Enables SPB-PIM Gateway on the interface. The default is disabled. |
OperState |
Displays the current operational state of this SPB-PIM Gateway interface. |
Address |
Displays the primary IP address of this router on this SPB-PIM Gateway interface. |
AddressMask |
Displays the primary IP address mask of this router on this SPB-PIM Gateway interface. |
HelloInterval |
Configures the PIM HELLO transmission interval. |
JoinPruneInterval |
Configures the PIM JOIN PRUNE transmission interval. |
